how to take paint of windows
hi i was wondering how you would take paint of the outside of the windows as i didnt mask the glass up properly and it looks a mess any help would be appreciated chhers
  • Replies 10
  • Views 1.2k
a sharp blade with a perfectly flat edge just scrape it off depending on how much there is might take a while tho
like a paint scraper,, are is that too rough
you can get blades from most hardware store or you can use a stanley knife blade but i would make sure its new so you dont scratch the window
good stuff,, would a razor blade and some wd40 work
use a cloth with a bit of petrol on it and it should rub the paint off
use wire wool, awesome stuff and cheap. used it on mine for the same problem its great
#as the man says.
cheers for the help,, bought a glass scraper and sprayed a bit of wd-40 every so often and wiped it with thinners came right off.
Well if you had thinners,you didn't need the WD or scraper - thinners or petrol on a rag were ideal.
Dont get them on the panel or rubber seal though,folks..
i tried it before, but it had went hard and it was £1 for the scraper so i cant complain
