Mk2 front end on Mk3
What needs changing just the front panel, wings, bonnet and bumper?
Matt
  • Views 987
front wings would need to be a mix of mk3 and mk2. the scuttle is different, as is the front panel arrangement. a very big job to change it
I reckon it could be done. My mate wants to use my Polo as an audio demo car for his shop and he's sponsoring the paint if I go mental with the mods. Mk2 front would be easier for some ideas i've got.
The scuttle is the same,the facelifted version even has the MK2's bonnet crease lines in it because its the same panel,i think he means slam panel.
The inner wings are the same pressing too,and even have the folds for the spot welds to the earlier crossmember panel.
Chassis leg extension pieces,outer wings,slam panel,cross member and bonnet need to go.
So in place - earlier wings,bonnet cross member,front panel and slam panel.
The only quirk will be that the base of the A-pillars dont meet the profile of the earlier wings,as they were flattened slightly so the revised wings could lay over them.
