9N Windscreen Water Jet Fault
Hi All,
We are not getting any water coming out the windscreen washers - here is where we believe the problem lies.
I think my dad cut the pipe because of a larger problem the car was having.
Now that it does not rain much the windscreen is getting difficult to see through.
Any suggestions?
Thanks!
  • Views 715
Does the pump work at all ?
What I would do is cut the rear window pipe and seal it (too difficult to replace and its not useful anyway) and replace the entire line for the fron pipe which is cheap and easy.
When I try to use it it does make the sound that it does when it works so I think we can assume that the pump works.
It's just that the pipe has some been cut/torn...but no water is coming out of it so it doesn't make sense, unless I am misunderstanding what that pipe does!
