possible stupid question? 6n related
hi, i want to tint my rear lights red on my valver, mainly because i like the 6n2 look but I'm a bit poor so going for the pikey versions instead..
The stupid question is... are indys, and reverse lights going to appear red when lit up after spraying them??
maybe should be in tech section so apologies if this is the case, move if necessary :)
Edited by blindy88
  • Replies 9
  • Views 949
ring a load of your local scrappys and pick up a set of 6n2 lights from them, they never want more than £15 :)
really! thats awesome! for some reason i had in my head that they would want like £50-60 quid! will get onto the scrappys immediatly thanks, easy job to fit??
Yes they will be red. White light through red tint equals..... yes you guessed it....Red or pussy pink.
Green light through a red tint equals....... Oh yeah baby that's correct orangey light (albeit usually not very bright).
So indicators can be done but that reverse light will be red for life bro. Although i read somewhere (on here in fact) that you don't even need a reverse light. So there you go pikey version complete.
Green bulbs and you can have your dream rear lights :-) (green LED bulbs may make a bright enough light through red tint although i have not tried it myself so cannot comment)
Best bet is buy 6N2 rear lights. If you do decide to buy pikey ones/use red tint spray make sure that you sand off any markings on the plastic before you start (as the tint spray will collect heavier here giving your lights the herpes effect). Do light coats and when done give it a few coats of enamal lacquer. Done and done, stand back and admire you acomplishment. High five yourself. Nod smugly in the mirror. Your task is complete.
Although to tint spray my lights to a factory looking standard (polo estate so darker tinted lights not available off the shelf) probably took me 3-4 hours of fooking around. So do 3-4 hours extra at work one week and buy some 6N2 rear lights AWWWWWWW YYYEEEEAAAH!!
Thanks, brilliant reply haha, I'm now looking in the mirror and smugly nodding to myself as I've just priced up a set of 6n2s with bulb holders for £18 from a scrappy in doncaster!! RESULT:D
Now just gotta get my completely non-technical head around fitting them, cant be that hard as theres a total retard living near me that struggles to tie his own shoe laces yet has managed to fit 6n2s to his car.. wish me luck!
oh and anyone got a link to a fitting guide, might come in handy if my poor brain struggles to make sense of it all, cheers!
Edited by blindy88
Mate you seriously cannot fook it up. Its like a few little bolts holding the old lights on and then just swap em over. I am sure a couple of mins looking at what you have and the penny will drop. Also see below there is a guide apparently :-)
Ignore my words I'm a fraudster.
Good work on the mirror nod. At £18. You deserve it.
8-)
Edited by demolover
A guide to fitting these lights would be like needing a guide to wipe your own bum crease :-) You won't struggle. The only thing is the 6N2 rear lights don't seem to fit fully flush when fitted to a 6N but i am sure a bit of well planned fettling could sort that out.
8-)
Incorrect.
There is a bit of faffing to be had. Which includes cutting, rewiring, then sanding a plug down and reversing the way it fits into the lights.
The indicators on 6n2 lights are in different positions to the 6n. There is a guide pinned somewhere in the technical area that I followed.
8-)
Incorrect.
NOOOOOooooo i gave out duff advice :-( I should never assume. That's blasphemy on here :-) I have only ever removed and refitted 6N rear lights and made an assumption. My only saving grace is that this is not in the tech section, otherwise i am in no doubt that i would have been banned for life.
Do as the man that has done this said ^^
Many a monkey have done this mod though so i stand by my earlier comment that if you can successfully wipe your own bum crease. You will be able to fit these lights.
I believe in you anyway. Don't let me down.
haha its ok dude I think were both getting banned for life, I've posted a tech question when it specifically says not to do so in this section :ninja: either I'm a rebel or a complete special child, fingers crossed nobodys paying attention and weve both got away with it ;)
I'll scan my eyes over the fitting guide just to fill me with some confidence before I start to pull apart wires, and I WILL NOT let you down, it means so much to me that you have faith in my abilities, however I fear this faith may be misplaced, await results.... :)
You too both just made me LOL.
Anyway, purely because you've both made me laugh i decided to point you in the right direction:
http://www.clubpolo.co.uk/forum/index.php?...ar+Lights+On+6N
You'll probably do as I did and get it a little wrong first time round. I managed to cut and reverse the correct wires, but I then forgot to sand down the plug and flip it inside the socket so for a good head scratching 5 minutes until it started to hurt I had my brake lights doing all sorts of funky things.
If possible, print off the guide OR write a few notes down to have with you while you do it... I kept having to go in and out of the house to read the next step and eventually tripping over the dog. Unless of course you don't have any dogs? if that's the case bark while you walk to scare any possible cats away. For safe measure.
