will it fit 175/50 r13 on 6J alloys on Coupe mk2.helpppp
Ok. The tyers on the car now are 195/60/r13 on 6j alloys with stock suspension, and they are rubbing like hell. i just orderd lowering suspension 4/3, and planning to put 175/50r13 on the same alloys. now the question is will they rub.
Please help!!!!!!!!!
  • Views 1.2k
shouldnt do. I've run 175/50s on my g40 whilst lowered 60mm and had no problems. you could run 165/55 tyres as another option. 195/60 are baloon tyres, so not suprised they scrubbed
should be fine as long as the offsets are fine :)
thanks, man. do you think should i lower it more or will 4 cm front and 3cm back be enoufgh. you got any pic. from that g40 lowerded like that with those tyers.
sorry, what do you mean by offsets?, the car is totally stock.
wheels were 5.5j wide but std et38 wheel offset
Edited by g40jon
