how to remove overspray of the wings
hi had a bit of paintin done on the car and i didnt mask the wings up,, its quite a layer of stuff any help would be appreciated cheers
  • Replies 13
  • Views 1.9k
Elbow grease and T-cut will do the trick :)
really,, its quite bad on both wings cheers
Claybar got mine sorted easy felt smooth too :)
got them done with t-cut :)
(Y)
cheers for the advice took quite abit of elbow grease but thats what you get for not masking up properly
bit of compound will get it off in 2 ticks
thinners
thinners
NOT thinners
if its the 6n2 as suggested in your name then thinners wont to anything to the paint on the wing, but its still not advised.
This is because the paint on the 6n2 is something called High Bake Enamel. Which is resistant to thinners to a degree.
The best thing is a clay bar and elbow grease.
Sean
As above clay bar is best. Not adviseable to use thinners
Wouldnt use t-cut either tbh, that doesnt do your paintwork any favors. Anyone that doesnt own one already should invest in a clay bar kit, i recommend the megs one. There just pure awesomness!
'bilit hamber' even better, and you use water for your lube. :thumbsup:
