clear out of mk2/3 bits
cleared out some more in my garage so feel free to make offers on any of it. not priced it all as its very low value stuff unless i have put a price next to it.
paypal accepted postage if your buying 1 wee item is likely to be more than the item! so please remember that. if you buy a wee pile of random bits will obviously do my best on the postage but i will need to buy some jiffy bags.....
located as listed on the left<<<< if you local come pick it up and can do most bits for almost nothing.
VW genuine sump guard bracket to TCA mount.
Rear Mk3 saloon rear wiring loom £45 posted ideal for GT/G40ing a mk2 loon as all the injection loom is built in.
Rear mk3 coupe/Squareback rear wiring loom x3 Varying conditions £20 - 35 posted
mk3 squareback key ring (chrome needs a wipe bit dusty) got it in Germany £8.50posted
Clear unetched front windscreen £15
Pair of clear unetched Quarterlights and rubbers (non bonded type) £15
Pair of door handles off a 31K car so still nice and tight with mounting bolts, black trim inserts and rubber base seals and lock unlock bit with retaining nut (everything except barrells) £14posted
Delocked drivers door handle with mounting bolts £4
passengers door handle with lock
passengers door handle without lock
windscreen washer pump x2 £1.50 each
full set of inertial real seatbelts with cover clips £5 each or full set posted for £25.
rear seatbelt mounting plates like new
alpine white petrol filler cap VGC of 31K GT £7posted
Anti roll bar rubbers genuine vw of a 31K car £5 posted
G40 plastic boost pipes pair £18 posted.
GT air intake for behind the crill 90deg bit and funnel from the grill
spare wheel out my squareback 155/70 x 13 - as new £5.
early version jack and retaining brackets, nuts etc all as new £20posted.
retaining rubber strap for late spec tool kit
rear boot latch like new £3
alternator lower mount to block plate VGC
passengers side rear saloon bulb holder
new vw fuel rail to inlet manifold retaining bolts star head £1
Dash blanks all 3 versions
header tank plastic guard with retainig bolts
old AA badge £9posted
orange side repeaters original VW
rear load sensor valve brakcet to rear axle complete £1
complete indicator/wiper stock £19posted.
AMP and 2ft of wire for Coil conversion £6
Boot plynth of my squareback standard black VGC £12 osted
Pair of wiper arms off my squareback can include the wipers £15posted
almost new (done 3K) rear handbrake cables (pair) £15posted
rear handbrake large and small retaining cages with the rubber anti vibration o ring
genuine vw under bonnet insulation/fire blanket vgc with all clips £55posted.
new 45mm exhaust clamp
vw and aftermarket rear O mounts
genuine vw blue rear exhasut mount that attaches to the body to stop the back box bouncing
blue engine sensor x2
black engine sensor
speedo cable £9 posted
GT/G40 flying saucer charcoal canister valve
hot air take off from the exhasut manifold fits all except G40
rocker cover studs set of 3 fit all except G40
brake light switch x2
GT/G40/genesis steering wheel silver trim insert £1
internal door handles with covers nad mounting screws pair
sunroof controls both GT/G40 black and standard polo cream
interior light
Servo unit complete £18osted
new rear strut bumpstop ( 2 metal washers and the 2 rubber bump stops complete for 1 strut) £2
mk2 golf/ mk4 polo electric window switches and 1ft of wire £9 posted
Gear box shift finger and cage
Radiator fan cover ( tool tray) G40 version £11posted
G40 powder coated inlet manifold (better than new)£50posted
new hella door handles £18 posted
new SWF (german made) relay with mounting bracket £4 (will work on most general items, horns, fogs, spots etc)
same as above but has a built in fuse (same style as polo ones) on the top £5
3ohm rear speekers and bit of cable £4
optional extra 4ohm front speekers.£4
probuablly other stuff in the pics too.
Also got BMW E36 rare parts:
Genuine EGR for BMW obsoltite Headlamp protectors with mounting instructions and fitting strips ( few months old) £55 posted
Coupe and saloon rear window blind manual version genuine bmw item with all clips and mounting parts £25posted
pics:
Edited by genesisGT
  • Replies 38
  • Views 1.3k
i spy a set of HT leads and dizzy.
fit a GT and how much buddy?
yeah got standard vw set and a silicone aftermarker set, and 1 has a almost new disi cap, so depends what combo you want.
just make an offer posted mate. £9.50posted for best of each?
If they will fit a GT then ill take them.
I just want the best condition HT's and Distributor youve got dude. I've got some horrid bright orange racing HT's on mine. Why people fit such crap to Gt's ill never understand ha.
What's this sump guard like then chief? Can't see it in the photos. Not that I'd know what I was looking for!
Jay yeah the cap and Leeds will fit a GT and any other Mk3 they are all the same.
Prankster its just the one of the brackets to hold it, its the bendy shaped bit of metal below the fuel pumps would need the other side and the guard from vw to complete or just another bracket then a bit of flat sheet with a 20 deg bend in it.
Oh, I thought it was the full guard. Cheers though
Is the fuel filter new? If so, sold! Also, I'll take the alternator bottom bracket too. Have you got the bolt too?
Ok Buddy, PM me some account details and a price and we shall sort it.
I'm interested in the 'rear number plate lights' how much for them posted, can you pm me the details?
all items paid for posted today.
pms replied to and list updated.
Interested in: Sunroof control GT/G40 (black) and GT air intake for behind the grille.
Also can the GT intake be made to fit on a 1.0 air box, like on induction kit? How much posted for both?
hello mate long shot but dont suppose you have the bracket that connects the rear axle to the under body of the car cheers
Hiya mate. How much would you want for rad fan cover delivered? Cheers.jay.
stumpymk2coupe - £7 posted only got the one with the G40 "ladelhauft" sticker left.
polo_phill - sorry no not got any left.
malaga red - yes it can be adapted to suit. typically i binned 2 bits of it last week and the bin mans been but got the 2 bits for behind the grill and a bit of the feed left. might have a feed and collor i made but will need to check.
Can post the sunroof handle and trims for £5 or with the 2 grill bits £10
ok cheers any way you know anyone who has got them?
You looking for brackets that attach the rear axle to the car? I should have a couple. No bolts though. Pm me if interested, don't want to hijack the thread
All bits payed for posted.
list updated
Ill take the Drivers side front seatbelt, if it works fine. Is it £5 posted? Mine just died.
pmed you back.
spare wheel an speedo cable have you got a price posted if you would?
How much for the fan cover/tool tray? Posted to west wales. Cheers.jay.
intank fuel pump and level sensor
how much on these posted?
Mike_Rigby - £18posted
stumpymk2coupe - £10 posted
JoeShorten2011 - not really wanting to post the wheel sorry. can do the cable posted for £8.
Edited by genesisGT
