Porsche seats
Ok I've used the serch but not had much luck.. I've been looking into changing for the later Porsche seats I know I will have to get the runners welded and that's not a problem.. I've looked a a couple of sets up for sale but they are moved electrically, is this hard to do etc..? Just want somebody to shed a bit of light on the subject before I commit and go ahead with it.. Thanks
Edited by vappolo
  • Views 639
well i fitted a set of calibra electric moving seats to my mates corsa b, you may have to look into it but you need to make sure that the motors etc that move the seat are fitted inside the seat or with the seat as some seats will require a control box so to speak, if all motors are supplied like it was on the calibra seats then all you should have to do is wire an after ignition feed to it and earth. Make sure you give plenty of wire length and don't fail like i did with a short wire that snapped when i moved it al the way back :-) hope this helps buddy and good luck, just look into it proper and then decide
