6n2 Door card covering?
Looking at covering mine in a suade style material has anyone done this with fabric if so what did you do did you glue straight on to the plastic? cover it in foam first then trim it? I'm wanting to do mine but wouldn't mind seeing some pics first as i think if it isnt done right it could look pretty shocking.
:paranoid:
I'm looking at doing the same thing to mine and was just about to ask the same thing. have you done it yet?
I'm not to sure about 6n2 door cards, can the area where the fabrice is be removed from the main door card?, ie is it on a seperate panel?
i have done 6n doors before, and what i did was used a heat gun to remove the black vinyl about an inch around where the factory fabric was and then heated the fabric up and removed it in one piece. i then laid it over my new matierial and then cut out the same shape. i then used spray adhesive on the matierial and stuck some wading to it. i then spray glued the whole area on the door card and fit it into place, but because i used wading it made it stick out slightly,so i stapled around the material and cut off the excess and then glued down the black vinyl again.
like i said the 6n2 door cards would be easier if they came apart, as you could remove just the fabric part and retrim that as aposed to ripping the whole door card apart.
HTH
