Alloy Wheels Paint Removel
hi, I've just bought some ats cups.. but they have been repainted ..Badly!! I've been sanding them down but its taking agessss! any ideas what i can use to get the paint off? I've been suggested nitromors but i searched a little about it and I'm not sure weva its a good idea :/ ??
SORRY I WAS MENT TO PUT THIS ON THE TECHNICAL ISSUES BIT
Edited by Liam16v
  • Views 266
Hi
i'm using always NITROMORS to get the paint off, but you need to VERY CAREFUL becouse it's verry agressiv,
the best is when you will put a little bit of nitromors to some small area of wheel to check reaction with your wheel
if its OK than mask everything what you DOND want to paint/polish and on unmasked area put nitromors
than wait 10 munutes, and using ie
http://cgi.ebay.co.uk/Scotch-polish-and-fi...a6#ht_500wt_922
remove rest of paint
can suggest you to wear gloves as nitromors can burn your skin!!!
before
Left before, right after polishing
1 wheel takes me about 4hours?
so you can do set in 2 days?
hope this help you
sorry for my english :)
cheers Adam
