Removing headlining
most of my interior is stripped out now and was thinking today i might strip the headlining out but was not sure if its all grubby and stiky residue underneath
and the best way to go abouts doing it
any one have any pics of it underneath or info would be great :)
cheers
Edited by 01mlacey
  • Replies 8
  • Views 1.3k
As far as I'm aware its a windows out jobby on mk1-3?
oh really
hmmm might give that a miss then
anyone else go ways around this ......
Yeah its wrapped around the seams,so to remove it properly you'd remove the window seals.
However,you could just hold back the seal and get a Stanley blade behind it,cut the lining and the seal will cover the cut.
Quite how good it'll look is questionable,and you wont be able to re-fit it (though you probably wont be able to,properly,in any case).
follow the tedious link --- http://www.clubpolo.co.uk/forum/index.php?...p;#entry2037240
EDIT: underneath its just felt and glue come of fairly easily then its just however vw painted or didnt paint it in the factory.
Edited by genesisGT
search button apparently gives you aids i heard :-)
Beastman aids?
Scary stuff :lol:
cheers man thats sounds spot on
but however time consuming think ill defo pass :lol:
