polo gti key fob programming/ pairing
i've just recieved my spare key back from repair. The red led now flashes when I press but doesn't unlock the car
The person who fixed it also provided instructions to pair back with the car but it doesnt seem to work.
Instructions I recieved:
1. switch ignition on
2. insert key to be programmed into drivers door
3. lock vehicle manually
4. press lock or unlock button
5. wait at least 1 second
6. press lock or unlock button again
7. vehicle horn sounds to indicate correct programming
Has anyone got any experience in programming keys; are the above instructions correct???
cheers
  • Views 2.3k
try it and find out?
I had to do something similar what you just stated with my 2003 mondeo.
My experiences are:
ignition on, off and on again and let it on
turn a key in drivers or co-drivers door to close and hold it there
press any button on the new key
now you should see the hazard lights indicating the successfull programming and you should hear the relais in the receiverunit down in the dashboard
ignition off, take the key out of the lock and now the new remote should work
Easy and quick.
Up to four senders for one receiver. Look for flipkeys with "433,92MHz" frequenzy which you can use easy instead of your normal remotekey.
Also via vagcom, there you also can delete lost keys/remotecontrols, means reset the memory of the receiver before you learn all existing remotes. But thats another story.
cheers
Christian
cheers
