remove seats help
right in the process of removing my front seat wanting to remove the carpet all together clean it and die it black to match my leather seats. thing is I'm having difficulty removing the black runner stops on the back. so the seat wont fall of runner. i have got one of the one nearest the door but can i hell get the other one off the longer one near the centre tunnel. any ideas how it unclips. also anybody ever removed whole carpet how easy is it to do.??
thanks
tom
  • Views 986
It should be a simple case of you just lifting it up towards the roof of the car and it will unclip, make sure the seat is pushed as far as it can go towards the front of the car so that it will be free to move when removing it :)
Hope this helps!
Hope this helps!
you mean the black stupid cover stop seat falling off runners of seat. i been told by a mate to remove the stops then slide the seat back and it will slide of runners hmmmm
tom
Hope this helps!
tom
yeah thats what i did came straight out mate
Hope this helps!
tom
Yer you have the removed the smaller black cover at the end which simply pulls of the end (it does clip in so use force if necessary :D) then take the other cover off and the seat should just slide off the runners as you said... for it to slide off the runners though you will need to remove the locking bolt which is actually on the seat at the front (you will need to remove this in order for the seat to slide off the runners... it's in the center of the seat and should just look like a normal bolt!
Good luck! :)
