TT pedal fitting in a 6n2
hey guys, i ordered a set of TT pedals from ebay, just tried to fit them and the excelerator pedal seems too short? it has a different part number to the brake n clutch pedal, they both start with 8N0 and the excelerator is 8N2 does anyone know if I've got the wrong part as I've had a quick search and seems people are using the lhd excelerator pedal? is it slightly bigger? many thanks.
  • Replies 11
  • Views 3k
yeah its longer and squarer, youll have to superglue the edges down to the accelerator or else it may fall off.
part number is: 8N2 721 647B
thats the part number of the one i have, it seems way too short though? its a RHD one, do i need a LHD one instead? are they longer. thanks for your reply.
I had a LHD one on my GTi. I've got a TT now and i'm sure its shorter yeah!
As above. I glued mine over the existing pedal cover. Just unclipped it, glued it on with a glue gun and clipped it back on.
I used 2 brake pedal covers for brake n clutch. Just modded the clutch one by cutting the inside bit out the pedal (you'll see when you try fitting it)
thanks for your reply I've asked them if they would exchange my RHD for a LHD they seemed a bit stroppy in there last msg. I've read a few places i need to glue it on so i will probs do that too, i had a set in my 6N polo and they fitted straight on and never fell off but i dont know if the pedals are different. my brake n clutch look like they will fit on ok just a bit tight.
Quick tip for the brake and clutch, put both the pedals in boiling hot water, it will soften the rubber so make it easy for the pedals to clip onto the pedal if that makes sense lol
wikid thanks for that tip ill defo try it :D thanks
Can you give me the part numbers of the clutch and brake pedels to fit a 6n2. what accelorator pedal can I modify to fit?
the part number for the clutch and brake begin with 8N0, just look for mk1 TT pedals, then u need a LHD TT pedal for the excellerator
http://cgi.ebay.co.uk/VW-Golf-4-Bora-Beetl...=item3cb338386e
they should fit.
they should fit.
I just bought these, if I have trouble fitting the I'll be back here :) Is there any tips/guide I should follow?
Edited by fantsypants
  • 5 months later...
Would this set be any use? It states it for LHD.
Not sure if they are cheap copies but I don't mind for £20 posted.
I don't know about part numbers but I've got some and they fit fine. I seem to remember the accelerator pedal being a bit of a tight fit but once it was on it was fine, no glue needed. Mine were bought from Awesome if that makes any difference
