6n2 clocks
Ok polo 6n2 i have the haynes manual but it description is 100 percent utter crap on this part lol
I need to remove my clock surronding trim on the interior (the speedo surround)
I no theres one screw central underneath to remove but where do i go from here everything i try i cant remove it its clipped in some how but cant see where and how and i dont want to b brute and brake it
Anyone done it before if so how? Thanks ppz
  • Views 1.4k
I'm pretty sure you just have to get mad with it and yank it, I'm sure thats how i done mine, i have a spare one in my room somewhere i could dig it out and check for you how it comes apart, pull it from the bit that attatches to the rest of the dash
‒ → Remove dash panel insert hood.
‒ Remove screw -1-.
‒ Unclip upper part of dash panel insert hood -2- in direction of arrow.
‒ → In order to remove the lower part of the dash panel insert hood -1-, the three screws -arrows- must be removed.
‒ → Now the two screws -arrows- securing the dash panel insert can be removed.
‒ Pull off connectors on dash panel insert.
‒ Take out dash panel insert.
Installing dash panel insert
The installation of the dash panel insert is basically the reverse to the removal sequence.
Thanks alot for the helpful replies so to clarify i need to yank number two towards the driver? Just dont want to brake the surrond lol yeah if u can find how the clips are situated would b a mahussive help matey
