Engine fell out!
My clutch died so i got it done at a garage because of a lack of time/tools.
Got it back and the guy said he couldn't get the gear linkage to line up properly so anyway it drtove good for a bit then the clutch gradually started to get worse and the vagueness of the gear shifts got more.
Anyway as i was going along, bloody rear engine mount falls off!!!! Forcing gearbox into forth. A formel e with only the forth gear is not fun.
Bolted the engine mount back on and I can see what he must have done, not taken the plate off and tighten it properly. Lazy ass.
okay have vented... unbelievable shoddy workmanship much???!!!?!? And i am left with barely any clutch left AGAIN!
Moral of the story - Even if you dont have time, make time and fix it your self.
  • Replies 12
  • Views 1.4k
Take it back and rant matey. I wouldn't be fixing it myself if I'd just paid some knobsock to do it!
Ohh I will, gonna demand a new clutch because its basically mullered the one he put in.
+1
Why people take a car away from a garage, when they know or have a feeling something isn`t right is beyond me, i`d say either sort it out or i wont pay you and i will just take it away.
Had a simirlar thing when i tried to get a lowerd car tracked a few years ago, to low to do it but they still wanted paying didnt pay after a heated chat .
Luckily i work in garage now so do all my own work, to many cow boys out there taking advantage of vunerable people.
id have that back at that garage first thing in the morning and tell him to do it right this time
Get a full refund if you can, and take it somewhere else. Bunch of cowboys.
i took mine to a garage tofit my suspension and when i was driving home it was knocking turned out they dint evan tighen it
since then I've done everything myself
if i were you goback there get you money back and doit yourself :)
want a job doing, do it yourself....best way
:nod:
+1
Felt good when I left then gradually got worse, just wondering if i had been going at any speed and it had fallen off then what?!
It was your fault for driving the car away...you obviously had the work done by a 'fitter' not a mechanic.
If I went to collect my car from a garage and they said they couldn't do an aspect of the job...then I'd not take the car until they found out why they couldn't do it.
The bloke who did your work just fitted the parts then left it, hence why I say he was a fitter. A mechanic would have found a cause for the problem with the linkage then performed a solution.
Well you live and learn, has put me off using a garage again though.
I had this happen when about to go into a car park. Luckily it happened just before but i lost reverse and any type of movement did not sound healthy. Some how got it home. Was quite funny trying to get slammed bready up a huge curb to turn around lol
