Fixing a sticky boot lock guide
Figured id take some pictures and do a little how to guide as it seems to be a common problem with a lot of mk1/2/3 polos
First off, remove the boot strip and unclip the lock part so you are left with something like this
I found it way easier to remove the metal locking clip
Then remove the circlip that holds the lock in place, as you can see, mine was a bit scummy...
The whole mechanism should now slide out (you need it unlocked)
Now you can see why it wasn't working right!
Now take the sliders out, make sure to keep them in the right order!
As you can see, there is a lot of crap on them
Spray plenty of wd40 or summat like all over the barrel and try and free up the tiny springs with summat small and pokey so they move freely and clean out all the crap from the barrel
Then clean the sliders, i just used wire wool and they came up all pretty like :)
Then oil them as you put them back in
then when youve put the sliders back in, try it out with the key to make sure all of them go flush with the barrel, like so
And bingo, assembly is obviously the reverse of before. Put it all back together and you have a working boot lock again :)
  • Replies 12
  • Views 1.9k
Nice guide man, you take them pics tonight? Think ill do mine when I come down in the polo.
Cheers dude :) When i saw you'd commented i figured it would have been about my massive fingers :lol:
Ill do it next time you're down if you want as I'm getting pretty good at em now! Yea did it tonight as i figured id better lock the boot as it now has all that stuff in it!
I started doing an FAQ for this and got so pissed off with it that I forgot to take photos. Lol
I take it the springs in yours were better condition than mine.
Its ok if you take your time, though i slipped taking the circlip off and made a right fucking mess of my finger with a blunt screwdriver :lol: and i doubt it, they took a lot of freeing! its nice though now to have a lovely smooth boot lock :D
Same. Been out of use for 3yrs. Lol. I cleaned the brass tumblers and then had the whole lot soaking in a sonic bath of wd40 all night to release the springs.
Nice being able to open your boot from the outside.
Great job on this guide. I did the same fix myself too, but as always forgot to take photos :oops:
Top guide, many thanks! :thumbsup:
Its awesome :) i hated wondering if the key was going to snap before the bloody thing opened :lol:
Cheers dude :)
I've done this, not long after it got stuck again, i would recomend greasing the pins
is the 6n polo similar as my maytes has packed up and he cant get in the boot, problem is boot is locked so how would i get his lock system out as i cant even open the boot? anbody can help me here
Take the panel off the inside boot and get in from there, you'll be able to disconnect the mechanism from the handle and flick the latch open. Then you can take the lock out etc etc
ok thanks :)
  • 3 months later...
This should be a sticky :) I'm trying to do mine now.
Already lost one of the little gold things...woops. I can see a new lock coming on...
Edited by DubLass
