Mk3 steering column mount snapped
As title, some local scum decided to try and have off with the polo.
steering lock held, column didn't as you can see below
i have managed to get a spare column (minus key) but am struggling to separate everything so i can rebuild it.
anyone done this before? am i missing something obvious
Craig
  • Views 626
end should tap of as its a bearing- you will need to insert the key to take the steeringnlock off before you can do this. does it not say in the haynes manual?
Sorted it, didn't think to just whack it apart with the tappy stick.
