Removing my aerial
I'm thinking about taking my aerial off and Blanking it, does anyone kno what size the hole is? And how to get it off?
  • Views 1k
If its the same as the 6n2, you unclip the bit of trim that runs along the back of the head liner, pull the head liner down enough to silde an adjustable spanner in there to undo the nut on the back. It then pulls off easily.
What would be the best way to fill in the hole if theres one?
I'm tempted to do it aswell, the standard aerials are balls :p
Cheers :)
Pull the trim off along the back and pull the headlinning down and undo with a spammer...
The hole in the roof is a square hole about 15mm just to let you know ;)
jamie
Edited by jamiet2
