bonnet catch adjustment
hi was wondering how to adjust the bonnet catch as i can just lift the bonnet up without pulling the lever inside the car cheers
  • Views 821
Before you make any adjustment, make absolutely sure that there is no other problems, such as the cable not allowing the lock to return when you release the handle, it may just be a case of oiling the lock.
Do take great care whatever you do though, as: 1) With the bonnet as it is at the moment, there is a real danger of it lifting whilst you are driving, especially at high speed, when the wind gets under it. 2) If the cable were to seize when the lock is working, it is a major problem to get the bonnet to open, as these things are designed to be pretty-well theft proof.
Regards.
