drivers door catch adjustment
hi i have to slam my drivers door to get it to shut properly anyone any ideas cheers
  • Views 722
As you don't say what model this is, the following is just general advice.
First of all, make sure that the problem is in fact due to the lock/striker plate, it could also be due to problems with the door seal or hinges that have 'dropped'.
If you are sure that it is a lock/striker problem, try a little lubrication.
If you still have a problem, use a very sharp pencil to mark the door pillar all the way round the striker plate.
Slacken off the striker plate screws slightly and move the striker plate OUTWARDS a little.
Re-tighten screws and test it, if there is some improvement, but it is still not great, move it out a little further.
You could also try moving it up or down, but a little at a time is the name of the game.
The purpose of the pencil mark is to save you time and bother, as you will be able to see from that which direction improves things, and which makes it worse.
Regards.
sorry its a 1999 6n 1.0
got it done cheers for the advice
