1982 Polo Gl 1.4 16v
the AFH mk1-3 guide on FAQ section.
dont see ARBs come up for sale often but you could scrappy hunt. i dont know if a mk3 one would fit, but i can see no reason why not.
  • Replies 181
  • Views 22.9k
cool man ill have a look out then :)
picked up some vwII caliper from a 6n for £15 :D
also spent some well earned dollar in GSF on:
brembo vented and grooved discs
greenstuff pads
goodridge braded hoses
new top mounts
a new track rod end as it was knackered
2 new bottom arms
need to get 2 front bearings and 2 new hubs, as i have got everything else new so i thought why not! :)
also got some coilovers of ebay :)
Are you after a 5spd ARB chief? I have one going
And regarding some of your questions above;
Some late mk2s were fitted with 5spd ARBs as standard. Yours won't have
Your fuel system will be fine, but you will need to sort a pump as your's is driven by the cam
You need the blue oil sensor, but just earth the yellow one (high pressure) or the buzzer goes off
You shouldn't need new hubs mate as they don't wear. I'm not even sure you can buy them
Edited by prankstar2003
yes i am matey by the looks of it :p
GSF do them for £21 each i think it was.. so i will prob get them :) i have a facet solid fuel pump.. so the standard 6mm lines will be ok, dont need to upgrade to 8mm ones?
from what i can work out my car currently only has one oil sensor.. any knowledge on this (its an early 1.1 mechanical head)
Have you got a picture of your oil sensor wiring? I had a mech head in mine. But forgot to take pictures :?
Gsf do hubs? I really dont see why you'd need them, but it's up to you. When I has mine apart, they were totally fine. Your fuel lines will be fine yes
If your after an ARB, let mr know
yeh man picking up the new hubs and bearings tomorrow! hopefully my coilovers will be here too :)
how much you want for the ARB matey? :)
That looks great! Proper classic and retro 8-)
Pm me about ARB chief
got everything i need for my coilovers and brake set up :).. booked it in a garage for thursday to get it done.. 2 days before welsh volksfest... a bit risky :p
There is no risk Dave ;) Get the AFH in! I tell you every day!
listen to him :-D ^^^
haha nice! is that tom with the g40?
haha ignore tom mate :)
I have vwII calipers now, along with brembo docs and green stuff pads. Is there an upgrade I can do with out putting a servo in to the master cylinder? Is a mk2golf gti one any better etc? Which one would be best, if any.. Thanks guys?? :)
Wow, wonderfull base :shock: Niagara green is beautiful and so rare (only on 82') :drool:
VERY nice second that on the colour front!! what wheel and tyre size are you running? and what 60/40 kit did you use? i really like the stance you motor has. thanks for the info.
cheers man always wanted to know the name of it! didnt know it was an 82' color only too :) thanks for the info!
my wheels are 13x6 ats cups, with 165 55 13 tyres on, a little stretch in the tyre wall but nothing major.. currently 80 on the front and has 1 40mm lowering spring on the drivers side :p ( couldnt get the bottom bolt off on the passenger side :( ) going on for coilovers all round on thursday so should be decked then!
any one got any info on a better master cylinder?????
knocked the lip in on my rear arches today with a soft rubber mallet and a heat gun.. worked a treat! no paint flakes! really impressed with my own handy work :p
coilovers and breaks thursday ready for volksfest wales this weekend!!
Is it written L94A on the sticker in the trunk ? It's the color code for Niagara Green ;)
ill have a check later fella :) thinking of a respray when i get the engine in and running.. (same colour of course) :)
she is in the garage, coilovers, brakes, new bottom arm etc etc etc.. so excited/nervous for getting her back and being ready for volksfest wales! :)
not ready for today! :cry: hopefully tomorrow :?
got the car back now with the coilovers on, brakes are amazing... and have started work on the engine :).. cannot make my mind up yet as too what to paint and what colour, any ideas??
also with the 5speed linkage which part do i need, the atcual gearstick end or the other end which attaches to the box??
still after a 5speed ARB too :)
any ideas??
Edited by Phayth
