1982 Polo Gl 1.4 16v
got the breadbin in my garage and took the 1.1 out.. the valver is now bolted in and looking good :) just need to spend more time on it and buy a few more parts and should be running soon :)
  • Replies 181
  • Views 22.9k
afh is bolted in and turning over, yet to set up feul pump and put the carbs on...
just a few questions,
1. because my car is an early mk2 i only have one oil pressure wire, will this matter?
2. the blue and yellow wire is used for water temp, do i need to run another wire, if so where?
nice one sir! lets see some pics!
placed mani on too see how she will look when i go down to prospeed :)
and this is the cats eyes killer itself, (old manifold)
concaved yo!
so please can some one tell me how to wire the oil and temp sensors and will it work with onle one of each? :) thank you please
You'll be better posting those questions in the appropriate section.
wow man, thats one nice looking afh! nice!
cheers mate I've emailed the appropriate people and put it in the engine section :)
thanks a lot just hope it goes as well as it looks :D
:drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool:
8-) thanks
nom nom nom! get the metal in that engine bay polished up :p
haha cheers mate, the steel would rust though :p if it was ali that would be a whole different matter!
still need advice on the water temp wiring and if its ok to only run with the 1 of each water and oil :/.....
thanks again :)
which alternator you running?
mk2 with the mk4 pulley mate :)
Ah, Caerphilly mountain. Homesick!!!
Cool car!
haha yeh man thats a trip back from caerphily polishers.. i lve in Dinas Powys (near barry) :)
Ah, don't know Barry so well. But I know that road like the back of my hand - used to go over the mountain to see my g/f (now wife) on the way home from Glamorgan Uni. Or go the other way from hers to the Showcase Cinema on the other side of the A4069.
Diversion! Sorry...
cool man, were you evere on the sowal forum?
Yep- still am (krupa)
engine now turns over,
not a lot lift to do now:
1. finishing wiring fuel pump in.
2. tighten driveshafts.
3. ARB mounting.
4. fuel pump mounting and plumbing.
5. timing.
6. cables.
7. gear linkage.
not to much :p
loving this build so far! I'm kinda local and in the middle of an AFH on EFI myself. Can i ask what sort of rates you aoid for the polishing work?
i got all the polishing done by a guy called paul and caerphilly metal polishers, was about £60 all in, which in my opinion is pretty damn good :)...
have you spoken to cymro on here, he is closer to you again and knows alot when it comes to bike carbing cars :)
sweet ill have to look them up. I'm not going to be using carb dude, I'm using the standard electronic fuel injection.
mk2 with mk4 pulley eyyy, i'm in the middle of changing mine to this set up...
which bracket did you use or did you have to make one?
also, did you just put the pulley straight on? or did you cut any off it?
i bought the mk2 alt with the mk4 pulley already on it, I'm going to use the mk2 mount but make up a backing plate to put the other bolts in :)
Cut the extra spacer part off. Also u need to put a groove in it to suit the mk2 alt. Then use the same sorta spacers ect as normal. Mine is aligned perfetly now :)
Okay.. Just the spacer or the 5mm of shaft between it and the pulley?
I'm doing it right now lol.
I've filed the groove so it sits on the woodruff key.
What bracket though?
