Security on pre-immobilised Polos?!
Hey All,
Getting an immobiliser fitted on Thursday... Just wondered if others have had this done and is it recommended :)
  • Replies 12
  • Views 1.2k
Security measures are recommended,yes. Generally,like. But i think a lot of splice-in alarms/immobilisers are a load of crap,myself.
Not gonna go into detail on mine,but to say that getting into the car is always gonna be easy,people ignore alarms,so I've chosen to focus on ensuring it wont go anywhere even with the door opened (i only lock it to protect from squatters vomiting in it).
Philosophy is always good - at home its usually blocked in and there's cctv,the stereo is worth twenty quid at the most. Away from home i use common sense,like parking it as close to anyones house as possible,or in very well lit and preferably cammed-up areas. I've even left it at a petrol station and supermarket entrance a few times,to save it being left in a more hostile area.
Same as mikey really, there are so many ways to get into a car like the early polo's easily its not really worth going over the top in that kind of security aspect. I've fitted a 6n engine and kept the immobiliser with it, may not be the most advanced form of immobiliser but it should be enough to stump the usual low IQ pond life long enough for me to get out the front door with my secondary for of car security :lol:
Way i see it is that if someone is that desperate and committed to robbing it then there aint too much you can do.
Just got to raise the level of commitment required to more than the thief is prepared to go through with. Like Mikey says, well lit areas, close to other houses etc.
If its modded a snap off steering wheel makes things awkward if you park it on full lock. Just other things like this really.
Just try to make it as awkward as possible for the thieving cnuts!
+1 if they want it they will take it.
Things like the crook bars for the steering wheel are a waste of time, and never really thought about alarms because no one seems to give a shit when they hear them anyway, i normally just resort to parking in certain areas and if i have a doubt in my mind ill take a plug off the dizzy or coil for a piece of mind :lol:
They did'nt get mine last year, in the process of trying to break the steering lock the burst the column off it's bracket rendering the car undriveable, steering lock was still on, column was flopping around all over the place :roll:, welded the bracket back on but was left with a squint column for a while, only recently got around to fitting a new one.
I fit one of those bar things that go through the steering wheel now, agree with Mikey on the alarms, never heard of anyone investigating a car alarm going off, tips on parking in well lit areas are handy, or parking in a non dodgey area, even if it means walking for a bit.
There is a battery disconnect thing, goes on the battery terminal (funnily enough), DisCarnect i think its called ?, has a knob attatched to a bolt which can be unscrewed and taken out, means that the thief would either need a 13mm spanner and bolt the right thread or some spanners to remove the thing completely and reconnect the battery.
One of those things i keep meaning to buy myself but have'nt got around to it :roll:
Ok if GOOD thieves want it they will get it! :lol:
Glad yours wasnt too bad mate!
They can easily be pulled off, as if you pull on it hard enough it bends the the steering wheel, or they just simply cut through the steering wheel with a hack saw and slip it off, the disk type ones which go round the whole wheel is much better imo.
^^ Yeah you just bend the steering wheel down,unhook it,then bend the wheel back. Takes less than three seconds in most cars.
Most of those things are so useless it takes longer to use the key - they're more a method of preventing a clueless driver from worrying than for actually protecting the car. Superstition science.
The only thing that puts them off trying to nick the car and actually works is a disklok.
The bar type steering wheel locks are just an extra lever to pull on to break the steering lock. Put some brackets on the brake and clutch pedals and padlock them together, then fit a line lock/bias valve in the front brake line with the lever hidden to lock the brakes on solid. Fit a hidden inline switch in the feed for the fuel pump.
Stopping people taking cars is easy (unless they've got a truck with a hi-ab). Actually stopping them breaking in is hard, easiest just to make sure there is nothing worth nicking inside. I usually leave my Polo open when parked depending on whether the radio is fitted or not. I'd much rather somebody got in and realised there was nothing of value in there, rather than smashing the window to find out.
Matt
the only car security device worth having
Haha - love it
I mean i'd like to think i have enough common sense to take on all those things. The immob i am having fitted is Thatcham cat2 - and maybe its more a piece of mind thing but i feel it is probably well spent
Thanks for your thoughts all :)
