6n2 gearknob & handbreak removal
how do u get the gear knob and hand brake off the 6n2
Thanks Richie
Edited by bass_p
  • Replies 10
  • Views 7.3k
bump
Try putting something descriptive in your thread title, then someone might read it.
:nod:
Buy a haynes manual :p
ok and can't i just have a real answer lol
Yeah, you just need to hope someone who knows the answer happens to look at your thread.
This is much more likely to happen if you click edit on the first post and type a descriptive title like '6n2 gearknob & handbrake removal'.
lol its true we all know the answer just want to prove the point lol
i get it ill change it if i dont still get an answer i wont be happy lol
Gear knob you need to pull the gear gaiter up so the surround unclips and pull it inside out, you will see a metal clip which holds the actual knob onto the gear stick you need to put a screw drive in the small hole and widen it so the knob comes off, for the hand brake there is a small plastic clip under the handbrake near the button you need to pull the clip away from the actual metal inside and this should free the outer casing and should slide off, just make sure there is nothing attached to the bottom of the handbrake.
thanks mate thought i wernt ever getting an answer
