rattle under or inside dashboard
1997 1.4 8v
Hi everyone.
I'm still in the process of tidying up my standard polo. Most the work is done now but I have a really annoying plasticy rattle coming from inside or under the dashboard.
Does anyone know what this may be? I've not dropped anything in there or removed the dash. It sounds like a creaky rattle if you get me.
Any suggestions appreciated, i really dont want to remove the dash as it looks a pig of a job.
Russ
  • Views 979
Check around the instruments and the housing round it. Mine has the same sort of sound from there but I've been too lazy to sort it out :lol:
cheers mate.
I shall have a look.
One of the rattles is the passenger's seat belt socket.
Can you buy foam or something like a tape to pack in the plastic pieces of trim that rattle? Something like Dum Dum but more spongey or a tape?
Russ
check around the centre console and especially cubby hole area, where the centre console meets the dash.
also another common one is the centre dash panel (where the heater controls are), as this warps with age and sometimes becomes loose.
"Can you buy foam or something like a tape to pack in the plastic pieces of trim that rattle? Something like Dum Dum but more spongey or a tape?"
-draft extruder works well, you can get it from b&q its pretty spongey, adhesive and felt backed. there are also tapes and other things available for this at car accessory shops, just ask them I'm sure they have something for it.
hth
cheers guys
i'll have a look when i get 5
russ
