6N2 TDI?
Hi
I'm looking to buy a 6n2 tdi, is there anything i should specifically look out for, I know a fair bit about polos but not the tdi’s. It has 110k is that a lot for a small diesel?
Thanks for your help
Harry
Mileage shouldn't be a problem if its been looked after, but checked the cambelt's been done at the right inteval (60k) and that the clutch is ok as replacing that and the flywheel ain't cheap! Other than that, it should be in good nick but check the rear arches for rust as that can be a weak spot of the galvanised body
Also get a Y or 51 plate if you can, they've got the cheap tax! :-D
itl be the best thing you do!! little torque engine :D and with a remap you can see the complete difference mate! I've had mine over a year and everyday I drive it its just a pleasure to do so! Also I'd do a hpi check mate as I checked st least 10 and they was all on the register so worth doing one of these text checks mate!
Edited by dub-matty
I've had a polo 1.4 tdi and lupo 1.4 tdi. Both great cars. Y plate or 2001 and 51 plate 1.4 tdi qualify for cheep tax bracket.
If you go for polo check that the gearbox is smooth they are known to have problems especially when going down the box.
Cambelts and water pump is a must at regualr intervals.
If you buy a polo go for SE spec as its much better than s spec, you get central locking, alloys, better interior.
My sister in law has an a2 1.4 tdi with 230k on the clock.
Thanks guys for the response, I shall be sure to check those things out
By the way, How do you check if the clutch is ok?
Check it bites well and doesnt slip and accelerate hard and check for any odd vibrations or anything because it could mean problems with the dual mass flywheel. Also listen for any off noises when the engine is idling because apparently when a dual mass flywheel is going it makes a noise at idle which sounds like two pieces of rubber hitting each other (well thats what the guy i bought my car off told me)
