can you sand and paint just small areas of a part ?
lets say you have a scratch on the boot .. can you sand and paint just the scratch area ? doesnt hvlave to be perfect... just reasonable.
thanks !
  • Views 701
thanks !
yes you can but would prob notice the difrence you would need to blend the paint and laquer into the old paint really ...but depends on the scratch could it be polished out or tuched up ??
jamie
well i have a few things to fix.
first is where the Polo word used to sit on the 6n. i removed it and now its all peeled over there.
second are the two side beams that are a bit peeled on 2 small sports.
the side door has classic scratches, would you recommend to touch up these without prep work ?
It is posible to do just depends on how good you want it to be really ...maybe you could just use a tuchup stick
Depends on the scratches if they arnt through to primer most can be removed with cutting compound or tcut and then polished up ...or are they more like scrapes
jamie
