Rust bubble by a door bumpstrip
Hi basically i have a five door and want to take the bumpstrips of the side as it looks like someones bent some of them in half!
However before i did i noticed a rust bubble that looks like its coming from under the strip, i dont want to take it of and rip my paint :@ so how can i a) sort this rust bubble out and b) get the strip off safely?
I also have damage to the paint on the top of the roof where birds have desicated!! Any suggestions?
  • Views 703
Pictures would help. Depends how bad the rust is. Also bird poop is very corrosive and can be hard to remove dependent on how long it's been there.
Ok ill attemp to put some pics up later on but for know the rust is about 2-3mm and it has bubbled the paint but not ate through it yet, the birds mess is off the paint but the previous owner left it on long enough to burn the paint making rings and holes in it not bare metal though any suggestions for now??
if it goes under the strip I'm pretty sure you would take the paint of as you say if its a 6n as they are stuck on well.. Not much you could do other than fixing the rust after ..
and as for the bird mess if the paints faded and dull may just polish out ??
jamie
Edited by jamiet2
The paint has actually burned, u can see the holes and layers of paint and looks quiet unpleasent,
As for the rust is it spraying a whole panel job? Or is there anything i can do about it?
