1991 Polo MK2Facelift Coupe (MK3) 1043cc in blue
Hi guys,
After my failed attempt at breaking it on here the last time (and the fact people never got back to me), I'm starting this again
REASON FOR BREAKING IS THAT THE HEADGASKET BLEW
RIGHTTTTTTTTTT!
Its a 1991 Polo Mk2F Coupe 1043cc AAU engine, 4-speed AKY gearbox.
Some pictures of it can be seen here POLO PICTURES
The interior is mint, the seats have no tears or markings that I am aware of. Seats currently have some covers on them with Wolfsberg logo on, kept the seats in good condition.
Carpet is good, I will clean it up it if any wants it, door cards are good, seats are nice and clean.
The water pump in the engine is new abrely covered 2000 miles, same as the cambelt and aux belt.
ANY PARTS NOT MENTIONED BELOW PLEASE PM OR E-MAIL ME AT: acoylite@hotmail.co.uk
Most parts are available for sale still.....
Broken Parts:
- Engine - Headgasket blew
- Drivers side front suspension spring = Snapped
- Rear bumper = one of the plasic slidy clips is bust, if your handy with a plastic welder would be usefull for you
- Backbox = tail pipe fell off it, and all the baffle has fallen out, load as hell, and sounds quite nice, but still equally bust up
- Boot Door = One small rot hole, that i've hammerited, couple dents, and the rear demister needs re-coppering as the lines have been broken
- Rear wiper motor = The plastic bit that lets the water pipe exploded last winter
- Drivers Seat - Outer (longer) cable has snapped - cheap fix might still have the cable hanging around
- Head lining - Has a small tear above drivers head, and another by the boot i think
- Antenna is pretty much buggered
- Roof gutter trims are buggered, both sides cracked at the ends at the front end
- Drivers side engine mount, cracked on alternator mount
Parts that are off the car so far are:
- Inlet Manifold
- Starter Motor
- Air inlet plastic bits
- Steering Column plastic bits
- Metal pipe from water pump to water pipe housing bit
- K&N Pancake filter for AAU and AAV SPi units
- Golf MK3 Top Hat and Elblow for SPi units to have cone filters
- Debadged Front Grill
- GT Clock Set
- Coil Pack
- Front Bumper
- Rear Bumper
- Rear trim parts (which includes: plastic speaker trim for the boot, rear seat belt tensioners, rear suspension strut caps, rear carpets etc...)
- Distributor (Non vacuum)
- Various water pipes
- Expansion vessel + old and new cap
ANYTHING ELSE JUST SHOUT OUT!
Sold Parts:
Throttle Body
Drivers side front wing
Drivers side door (everything exluding the door card)
Fuel filler covering cap
Plastic bump strips for the doors.
Front wiper arms.
Return Fuel Pipe
BOTH Wing Mirror Interior Trim Plastic
Front Washer Jet Piping
Injector Unit
Edited by Acoylite
  • Replies 41
  • Views 1.9k
I can vouch for this chap - good man, fair prices and everything is as described. Would be happy to deal with again
speaking of that, how were the parts???
did they come up nicely??
I've erm...*cough* yet to fit them :roll:
hahahahhahaa
just like me with breaking the car down then :p
let me know how they go :)
alright, i need a part, dont no its name, the igniton set sits on it, its black and the stering column runs through it, two hex keys hold it onto the dashboard as well as a bolt, desperate for this!
hi mate, just woundering how much for the breather hose out of the rocker cover down under the engine and the hose under the air box which is a which one both need to be in good condition please and how much the passenger side black plastic cover which is on the door where the wing mirror screws on ?? please pm me
hahhaa, will take some random pics of the steering column for you, and if you can highlight what you need, i will rip it out for you :)
I need the full washer pipe setup for the front washers. Everything between the pump on the washer bottle and the nozzles on the bonnet. Also after the 2 inner covers for the mirrors as long as they don't have adjusters in them. Can you PM me with a price for these posted please dude.
Alex
heres some pics of the steering column
Still many parts available :)
Does this have the trim that runs along the top of the sills?
Where in shropshire are you? Am after some trim pieces
near bucknell :)
i think the ends of the roofy gutter trimmy bits have split at the end
could be plastic welded if your good, or super glued, but otherwise, i think its knackered
will get some pics up friday probably, totally busy at work at the momento
how much for the debadged grill including postage if its not sold mate?
How much is the amp? How old is it And whats the specs on it?
sorry all that jazz has gone
gt clocks? if u include the plug from the loom so i can fit on my mk2?
What colour blue is the polo? If it's steel blue, does it have a sunroof?
How's the rear wiper motor?
It is Steel Blue
No sun roof.
I have no idea how the rear wiper motor is supposed to be.
Opened it up after winter and the pipe attachment has snapped
Now i'm not sure if the pipe attachment is replaceable or not
Whether its a piece shoved in there on the pipe, or a piece that is actually part of the wiper motor itself
Otherwise, its fine, just the water jet pipe joint thats gone
hi mate, need the speedo cable. how much do you want for it?
It is Steel Blue
Is it definately Steel Blue or could it be medium blue?
After a passenger door.
Cheers,
Joe
It is Steel Blue
Cheers,
Joe
i think that chap will know, he did buy the other door off me a while back
