2007 Candy White Polo Gti 9n3
Hi Guys, heres my Candy White MK7 Polo Gti, just bought the car off a guy called Dale who is on here
Absolutely love the car and everything about it, sorted out a few small problems and have a few plans for it
Current Spec
Candy White 9n3 Polo Gti 1.8 Turbo 150BHP
All Normal Gti trimmings
Exterior
FK Front Anti-Roll Bar
FK Coilovers
Adjuster cups removed on rear
17" Audi TT Comp's Refurbished in Satin-Black
White Dice Valve Caps
Falken Tires
Front VW Badge sprayed Satin-Black
Front GTI Badge sprayed Satin-Black
De-wipered Rear
Lighting
M-Tech Front Main-Beam Bulbs
Engine
Standard........for now :p
Done a few bits when I got her, Dale has looked after this car well! But there was only one or two things I wanted to sort, Firstly the passenger window was not working, this turned out to be a rusty connector in the rubber tube from the door to the chassis which had been previously replaced. This was an easy and cheap fix thankfully.
Also because the car is quite low, the front drivers side drive shaft was knocking the anti roll bar when going over bumps, so a modified FK anti roll bar sorted this out nicely!
All that was left for now was to be machine polished using a Meguiars G220 Dual action Polisher and AutoGlym Super Resin Polish and Ultra Deep Shine
Firstly the car was clayed, then polished, then finally re-sealed with AutoGlym High-Definition Wax
Plans soon are -
Forge 007 Re-circ Valve
Forge Front mounted intercooler
Forge Intake Hose
Milltek Resonated Full System
Custom Map
Hoping for around 220bhp and will be happy
Hope you all like it
Mike :-D
Edited by Welsh_Gti
  • Replies 13
  • Views 7.5k
stunning car.
Love it... looks awesome on the tt comps. A friend of mine has one pushing 220@ wheels. Get it mapped you will never look back. Well done :-D
Looks well that mate! Good work
looks nice really like them seats as well and i usually hate patterned seats
Thanks for the great comments guys, glad you like it!
Nicely done, would say a bit lower on the front though? Despite the driveshaft knocking.
The front is wound down all the way. It could be a bit lower because it doesn't scrap over speed bumps like it should :D plus I have plenty of spare Cupra slitters after braking two on my seat Ibiza lol
Yeah even lower than that it probably won't scrape if you go over them slow enough or stick your wheel in the middle of the bump.
beautiful! could i suggest doing the rear badge black as well? :thumbsup:
The car looks sweet! What size tires are you running?
I shall have to consider the rear badge going black, i like the sound of it Hutch!
Need to respray the front VW badge and Gti badge
toptay12 - There 205/40/17 all round
  • 2 years later...
did you take those pics in bluewater carpark (looks like it)
Lovely car this!
