can this peek be fixed at home ?
check out what happened when i removed the polo badge.. the paint has peeled leaving a differnt shade of blue. polish doesnt work.
i have a lr5y matching vw spray and laquer at home.
can i fix this at home ? what are the correct steps of fixing this problem ?
  • Replies 9
You can try to flat it with 2000 wet and dry then machine polish. You may loose it.
will flattening and respray followed by hand polish work ?
I T-cutted mine out!
I have Turtle Heavy Duty Restorer. is that ok ?
Try it, nothing ventured nothing gained
think someone already had mine off before, as when i took mine off there was the polo outline showing where lacquer wasn't present...
any advice on that one...?
i just sprayed 'em black n stuck 'em back!
d.
Alright i polished it 3 times and it didnt budge. Sand and respray the area ?
Mine done the same try this, put petrol on a cloth and scrub till all the excess glue is off, then as green polo says flat down, id use 2500 wet dry with something lubricated and wet ie washing up liquid in water, try and focus just on the shaded area, then give it a light rub till u feel right dont over do it though, then use a really fine polish compound i use 3m the marks should go, but be warey u may have restored paint where you are badge was but you are whole boot may have a different shade as that technique is use for leveling paint and restoring a finish
Flat it with some 2000 wet and dry paper, keep the paper wet.
Flat it untill it all goes dullish and then get some G3 and water on it with a machine.
That should sort it. Make sure you don't go to far with the flattening and always keep the area you're G3ing wet.
