17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
Posted somthing up a while back and got no replies , i just need a bit of guidance.
2002 polo 1.9Tdi sport
From vag com I've got this code come up
P1256 - 35-10 - - - Intermittent
Readiness: N/A
Link to rosstech page
http://wiki.ross-tech.com/wiki/index.php/17664/P1256
Does anyone know the location of the temprature sender ? , some one mention it before looked the item number up in haynes manual and it as diffrent so I'm stumped with that one.
I've also ordered this from the last post not sure if its correct -
VW Golf Passat Bora Polo Temperature Sensor 06A919501A
I also got this (i think its incorrect though)
Volkswagen Audi Coolant Temperature Sender 059919501A
Mart
Edited by mpsheen
  • Views 9.6k
hey I'm sure the coolant temp sensor youve ordered will be fine for the car, and I'm not 100% on this but the sensor itself is normally situated on the right handside of the engine (passanger side) into the block close to the side of the manifold.
hope this helps
Ahh sweet , thats the bit i started to take off aswell! thought it was wrong so i done it all backup what an arse
When i figure it out ill post it up (with pics) Hopfully this thred will be indexed on search engines
  • 7 months later...
anymore on this?
need to replace mine tomorrow.
