Biggest brakes i can upgrade to on my 14's
Hi i have a 1.0 8v and was looking to get bigger brakes on the front as will be having a bigger engine in the summer these are my wheel specs that i know.
4x100 14 inch 8J with a centre bore of 57.1
Not sure on the offset, however the rear of the wheel measures 11.5cm from centre to the rear, and then from the middle to the front of the rim is 10cm.
215646_215685828443655_100000067181964_8
If i can get bigger brakes could you let me know which parts i would need to purchase?
  • Replies 25
  • Views 5.9k
Well i have 14" p slots on my mk3 polo and i can just fit 256mm brakes under them!
i was able to run my standard brakes on 13's with about 1mm of room but these wheels are no where near as close do 1.4 16v have bigger brakes?
16V brakes are 256mm and they will fit under 14"s and they are bigger than your standard ones. If you wanted to go to 280mm g60 brakes they won't fit under 14"s, hope that helps
Ok thanks a lot for that do you know which parts i would need to convert my 8v to 16v brakes?
16v calipers, pads and discs i think - i dont know if the master cyclinder is bigger tho which would also help.
I remember walshy's 20vt ran 14s, but he spent a lot on custom wilwoods iirc :thumbsup:
16v you need the hubs aswel as calipers discs pads.
biggest brakes u can fit on 14" wheels, is dont bother keep you are standard brakes on there good enuf, i have a set of 14 inch wheels and my brakes are good enough to stop me in an emergency and thats in a TDI not a pisspot 1 litre
So i will need:
16V Hubs
16V Calipers
16V Discs
16V Pads
to covert mine to 16v brakes? :)
that was helpful mate! :roll::roll::roll:
you can fit are 256mm discs with lucas 54 calipers, 270mm discs with vw2 calipers (with the appropriate adaptors and discs) or run wilwoods or similar 4 pots.
clearance of wheels will be an issue dependant on the design of the wheel, they may need spacing out.
I have 175bhp and I run 239mm stoppers.. :ninja:
you also drive like a granny with glaucoma
So i will need:
16V Hubs
16V Calipers
16V Discs
16V Pads
I have a set of carriers and calipers if your after a set. Drop me a pm if so
:lol::lol:
I also have a chassis which goes around corners. :lol:
quite handy when your local euthenasia clinic is situated on a blind bend
Hey man, stop breaking my balls becuase I drive a Golf! :lol:
The ABF's quite cool in it, similar power to the G40!
Dont compare it to a G40!
haha just messing with you ricardo! ABFs are sweet lump and the mk2s handle bloody well, just not a fan really over mk1 goofs.
get your ass to all types molicker
I know the Golf is in a way higher league.
You made me cry at work! :crybaby:
What/where is alltypes? I am game.
you been living under a rock?! north wales bitchtits. get involved and get barney mcgrew down too
you been living under a rock?! north wales bitchtits. get involved and get barney mcJew down too
Fixed it for you.
But no way am I going to Wales. I am broke as fuck, plus I have a hot little student in my bed waiting for me. Car's or ass? Hmmm.. :lol:
bring the ass with you, ill take care of her!
I just asked her and apparently she's not a fan of little burnt sausages, sorry. :lol:
tell her I'm not a fan of surprise sex, but its gonna happen =D
