6n twin airbags?
hi guys, looking at buying a 6n on a S plate it appears the have a passenger air bag - is this a device easy to disable? As regularly have a baby in the car with a rear facing car seat so need for them to be in the front.
also, when you guys buy a new car do you swap your insurance straight over? As we're taking my old car to view then need to be able to drive both of my cars home if I buy it.
thanks
  • Replies 8
  • Views 1k
not sure about the airbag... maybe there is a fuse or relay or something which you could remove to stop it working.
As for the insurance, drive to the new car, if you buy it, drive the old car home (leaving you or someone with the new car), then do the swap, usually takes 30 mins to change over, then bring the new car home.
Or just be a shady git and drive it home with you old insured car following you close behind. (remember though, this is illegal and I in no way recommend this method other than as an absolute last resort...)
Where abouts are you. i can dissable it for you :)
pm me
The airbag is not easily dissabled, you have two options, via VagCom, or permanently by disconnecting the plug and fitting a resistance plug.
As for the insurance, check to see if you can drive another car not registered to you, if so you will be OK to drive the new car home, then transfer the insurance to the polo, if you can't drive another car, your safest bet would be a 24hr policy normally they are around £30
Hmm so I guess this is going to be another thing I've got too factor into my buying requirements now. Damn. Missy needs to hurry up and grow so I can put her in a different car seat :|
Easiest way would be to replace the airbag with the full glovebox and put the resister plug on to fool the airbag ecu, then you will have plenty of storage for the little un's toys!!
Once it's disabled by the plug, unhook it all take it out and replace with a Glove Box.
if you go ahead with this, I'm in beccles and will happily swap my glovebox for a passenger airbag :p
jodybrown you may have a deal, I'll let you know when I buy one and we can sort out a swap!
