Advice on buying a 6n2 gti
I'm looking to buy a 6n2 polo gti , not too sure whats a good price to pay for one , and what i need to look out for when buying one , anyone on here give me some advice whos bought a gti ? looking to buy the top spec gti with leathers etc :D
  • Replies 32
  • Views 5k
i'm not too hot on prices, but you get what you pay for. things to look out for are pedal box andgearbox, also with so many electrical toys you need to make sure they work (it's not a reason to not to buy, as long as you know how to fix it) but those are the common things also if its high mileage service history is important.
When I bought mine, a few months back, prices where around £2000-£2500 for high mileage/or no history etc etc. I think youll need about £3000 for a decent spec one with history and good mileage.
But I suppose is its been looked after, mileage shouldnt be too much of a deterrent!
But defo test the gearbox, and if you can call up VW to check is the pedal box recall has been done!
Also try and get leathers, or youll have to retro fit some as I am doing now...pain in the ass with loom :mad:
Gearbox (Rivets Fail - Look for gearbox oil and/or Noises and Nastiness)
Windows - Fail (Check they move up and down automatically using the buttons on the driver side - it should allow you to put both up and down automatically with 'one touch')
Wheels - Prone to Laquer Peel and Then Require a Refurb - Costs a good £200+ so bear that in mind.
Air Con - Check it works / gets cold - if not knock money off as it could be costly to fix or cheap if just a regas!
ABS - Common Faults include dodgy control units or something as simple as a sensor or fuse - best to steer clear of ones with problems.
Horn - Check it works - apparantly they fail...
On top of this check cam belts been done think they are due every 60K.
On top of this check the exhaust - standard replacements are VW only and cost over £300. Uprated aftermarket ones are common sights now...
I think thats it - as mentioned a good one is £2K-£3K
Mine has had a bad repair in the past to the rear quarter and had it up for over a month @ £1800 - only had one person show!
Mine is probably a bad example but there are good ones out there!
Yeah sorry forgot this - make sure this has been done - good shout!
cheers guys this has helped a lot
For Godsake make sure it has the blue headlights and gti grill at the front. chances are if it hasnt then its been involved in an accident and repaired cheaply as the headlights are expensive.
i recently bought a 6N2 gti.
luckily its had its gearbox and cambelt done
when i bought it i was aware the discs and pads needed replacing
the offside wheel bearing needed replacing.
the exhaust had a corroded bracket and needed replacing.
and the abs light was on
i was told the abs light was a sensor so went ahead and bought it for £1100
when i got it to a garage it turned out to be the abs pump and apparently i could only get the part from VW themselves for the generous sum of £800 fitted.
I have since sourced one from a scrapyard which has exactly the same part number for 1/5th of that price, will soon to be fitting it to the car myself.
and still saving for the other parts.
Be very carefull though when you buy.
Since reading this post i have realized that my offside window will not close its self automatically, it needs help (as if theres too much friction or gravity)
Bear in mind these are tidy fast car, and could been hiding a history of molestation by boyracers and idiots.
BUT!!!! Dont be put off by these seemingly endless faults. They will put a smile on your face, that one time on that open, clear country road :D
that!
Every car has it's fault at the end of the day.
As well as all the above, check the central locking - The pump is prone to failing, and the boot light micro switch.
Sticky or FAQ this one i reckon - its got some good info....
fucking hell dave where you been hiding? :lol:
In a company Ford Focus! :ninja:
If you get chance to own one go for it,bloody love mine,had it bout 18 months, 62k on clock when i bought it,fsh, i paid £3500.
Check for rust, becoming quite common on mk5s now, sills and rear wheelarches.
I want a 6n2 gti now :(
i thought they had a galvanised body shell ! Anyone else know
you not up this way any more? take it the rallye's long gone?
they do have a galvanised shell and are pretty much free from rust unless its had spray work done or non OE panels.
Nothing i can really add to the list of stuff to look for apart from buy one. Enjoy it and put asside the gearbox wows.
I covered 27k in mine in 2 years of ownership and it was a fantastic little car. Had to look pretty hard to find something that satisfied me aswell even then i'm now on my second TT!
Ahhh neil, sat in a TT the other day and now wanting to swap my GTI in for one! Would you recommend?!!?
I bought my 6n2 GTi in March this year, cost me £3,300 with leathers, 1 owner, full service history and 27,000 miles. I'd been searching since October last year and it took me that long to really find a well looked after one but defo worth it!
Bought my GTI around 2months ago. £1550 ;)
i will dev buy a gti polo was thinking of just buying another 6n but thought I've had one for 3years time to upgrade haha !
Thanks a lot for this advice guys , it has helped a lot , I'm currently searching for a gti polo :ninja:, not too sure what colour to go for ?.... looks great in red i think ;)
RED
aah dude! I was down west london way this weekend if i had seen this post you could have had some V6 fun!!
I recommend them completely! Such a nice place to be in when you dont want to mess about racing or driving enthusiasically.
motorway cruiser or with a v6 quite alot of fun hooning about.
