Boris' G40
Hi everyone, just joined. Heres the G40 I bought as a non runner:
208398_1931519121026_1033688202_32340559
Has low compression on cylinders one and four, which I was sure was down to an incorrectly fitted head gasket. The cylinder head had been done just before I bought the car. So I got to work replacing it:
221898_1942342591606_1033688202_32356878
217311_1942342831612_1033688202_32356879
221758_1942343031617_1033688202_32356880
222950_1942342351600_1033688202_32356876
G-lader was looking a bit beat up
222379_1946223688631_1033688202_32364972
So gave it a wee spruce up
217295_1946223368623_1033688202_32364970
222423_1946223888636_1033688202_32364973
Removed head
215432_1954580417544_1033688202_32377407
227017_1954580577548_1033688202_32377408
As you can see, lots of action on cylinders two and three, not so much on cylinders one and four.
So I've replaced the head gasket (thought I'd taken a photo of the two of them together, but doesn't seem to have saved. Oh well)
Head back on and camshaft refitted
224379_1954580657550_1033688202_32377409
Mostly rebuilt.
227187_1954607898231_1033688202_32377502
As it turns out, the problem persists.
I'm fairly sure its down to worn piston rings, but I've also been told it could be down to worn or damaged big end bearings. Gonna do another pressure test when my kit arrives to help diagnose.
Currently trying to decide which route to go down.
1. Strip engine again, and replace the piston rings (may not be the fault).
2. Have the full engine remanufactured (sent off to a company who can rebuild it as good as new)
3. Find someone who's selling a PY cylinder block (no joy as yet).
Thanks for reading, sorry its a bit pic heavy.
  • Replies 21
  • Views 2.7k
did you have the head skimmed and pressure tested?
are there any marks on the bores when you turn the engine over by hand?
I can't confirm if the head was skimmed and pressure tested as this work was carried out by the previous owner. The receipt only mentions valve and guide replacement work.
Didn't notice any obvious marks on the bores.
nice ride man, good to see you getting stuck in. welcome.
where did you pick this up from?
Thanks mate :-D
Bought it from a fellow dubber (who has a very nice, mega low 6n2), from Bo'ness, who bought it from someone from Creiff. Car was owned by someone in Derby before that.
Thought that might happen :lol: Those wheels are terrible. :shock:
Really interesting to read and see whats been done to it previously, I knew it had been well looked after from its current condition. Got some plans of my own once I get the engine problems sorted.
Edited by BorisG40
belonged to polo6n1600i and 13kpologt on here!
Did a pressure test:
Before:
Cyl 1: 6 bar
Cyl 2: 13
Cyl 3: 12
Cyl 4: 9
After adding some oil to cyl's 1 and 4:
Cyl 1: 9
Cyl 2: 13
Cyl 3: 12
Cyl 4: 11
Confirms what I suspected in that the cylinder rings are knackered. Luckily, I managed to source a replacement bottom end from cheddarcheese on here. So stripped the engine again today, this time down to the bare block ready for the swapover. Just waiting for the block to arrive which should be on Tues.
Have you still got the knackerd bottom end? Would be willing to take it off your hands if you were thinking of getting rid of it
How did you test if the rings are fried then mate?
interested :-D
Yeah, I've still got it, switching them I've next weekend hopefully. Wasn't planning on selling it to be honest, was thinking of re-boring it, fitting bigger pistons and repairing the damage to the bearings. If I do decide to get rid though, you'll have first refusal. :-)
interested :-D
Rings aren't fried, they're worn and not keeping a proper seal. The oil I added made a temp seal during the test which confirmed they were the problem and not the valves in the head etc..
Ah right, i meant worn and not fried, don't know why i put that.
Just a case off adding a bit of oil down the plug holes?
That's right, just a small amount to create a temporary seal round the piston.
Arrived today.
230988_1995756886930_1033688202_32432886
happy days:-) good luck with the rebuild
How do you get an engine onto a stand without a hoist? Bodge it of course
231036_2004817713445_1033688202_32442340
Finally got there though after using another two sets of ladders and another baton to lift the other side. Left me with this:
229221_2004819433488_1033688202_32442343
Some gunking and a coat of paint later:
226900_2004819193482_1033688202_32442342
So now its ready to be fitted next week if all goes to plan.
Day 1 of the engine swapover:
254489_2021666414652_1033688202_32460615
Out with the old
253539_2021666654658_1033688202_32460616
252664_2021666814662_1033688202_32460617
In with the new
247739_2021667054668_1033688202_32460618
254209_2021666174646_1033688202_32460614
Finishing the rebuild tomorrow and hopefully starting it up.
Edited by BorisG40
Well rebuilt the engine today (didn't bother taking any photo's, cos you've seen it already. Anyway, all went to plan, checked the compression with the new bottom end and three cylinders are at 12 bar, one at 11, so that worked out perfect.
However, when I start it up, its as if its only running on three cylinders. Revs ok, but wont hold idle and runs rough. Checked everything, including the timing in case i'd missed a connection or vacuum hose somewhere, but all seems in order. Now I'm thinking I've a dodgy spark plug somewhere or an injector blockage. Thoughts?
Ht leads were running clockwise instead of anti-clockwise. D'oh.
Now idling and revving great, but still has a hesitation and not getting full power. New ht's are on the way and I'll be checking the plugs on Thurs. One step closer though. :D
vid
I was happy ok, thats why I said G60 instead of G40 ok !!!! :lol:
After fitting new spark plugs, the car is now running sweet as a nut. :-D
Anyone want to buy a merc?
