rust removal and resray guide
i want to remove the rust on my car and respray the areas
i was just wandering if anyone had any tips for me or a guide i could use?
I need to do this too, got some horrible rust patches :(
interested as well, got some rust on the inside of the passenger door.
1. Get yourself to your local car store (halfrauds if theres no good ones around).
2. Buy yourself a range of wet and dry (sandpaper) starting with something like 100 grit, then 220 grit, then 400 grit, then 600 grit, (and also 1200 grit if you want it to be perfect).
3. Buy some primer/rust protection primer.
4. Buy some car body filler.
5. Buy a tin of the paint for your car, get the paintcode from your car (usually located on a sticker in your boot or its also in the owners manual/service book i think. And laquer if that paint requires laquer, (ask the shop assistant) (halfords are usless)
5. Mask off any parts you dont want to get paint onto with masking tape.
6. Begin to sand down the rough rust with the 100 grit paper until your down to bare metal, then use the 220 grit, then the 400 grit, then the 600 grit, until its smooth as. (take your time and get it right)
7. Filler any bits hat are pitted/shitty an then sand again.
8. spray the primer onto the patch that you hve rubbed down, keep the can about 20-30cm's away from what youre spraying at so that you dont get runs in the paint, spray across it from left to right then release your finger, then hold the spray down again and then move from right to left. (possibly repeat if not much paint has come out)
9. WAIT! for it to dry properly, usually about 5 minutes, then rub down with the 600 grit and repeat that process a few times until youve built up enough primer to cover it.
10. Leave it about 20 minutes after you last coat and then rub it down with 400 then 600 then 1200 grit.
11. Repeat the same processes with the paint you have bought, then do the same with a bit of laquer (if laquer is needed for your paint.)
12 If it still doesnt look right, flat it off with the 1200 grit and buff it up with a buffer wheel and it should look fly like a g6.
Dan
Very nice, thanks !
What if it's just some surface rust on the side beams ? Can I just give it a nice buff with some 400 grip, then smooth up with 2000, and paint it ?
It's all flat on it, just that some of the paint has peeled, and the metal under is is not perfectly silver..
Very nice, thanks !
Still need to primer it dude and laquer (if needed) or else the paint will just crack off eventually
