2003 9N Polo "E-Class"
I'm thinking of buying a 2003 9N.
Are they good cars ? Any known problems like in the 6n2 (throttle and windows) ? Or is it a reliable car with no particular repeated problems ?
  • Replies 9
The 2 common ones:
Front suspension bushes (inner rearmost - "console bushes") which I would recommend you don't try to change yourself! (I did - wish I hadn't!)
Expect leaks in the rear washer hose. (every joint, and occasionally where it goes through the wiper motor) (check the jet doesn't rotate - it should piont vertically up the screen while the wiper wipes)
Others:
Coil packs
Throttle body can fail
Wiring failure at reverse light switch
Electronic module that makes the dashboard noises (including the indicator tick-tock)
That said, my partner's had hers from 5000 miles from new, it's now done about 75K. (all the above except coil packs have died on it too!) Still on original springs/shocks/exhaust/CV boots... in fact all the stuff you'd expect to have to change!
I find the driving position uncomfortable (particularly the "knee shelf" below the steering wheel!) the brakes sharp and the steering stupidly light. The economy's not as good as you'd hope as it's a heavy car for a small engine.
Would I recommend one to a friend? No. But Karen loves it!
Would you take a 6N2 over this ?
I love the 6N2 but the interior on the 9N is like x100 the one in the 6N2.
The 9N looks like a proper german car... Reminds me of a Merc inside.
Basically it's either a 6n2 16V from 2001 or a basic 1.4 9N from 2003
The price difference here (in israel) between the above 2 is approximately 2000 pounds.
Edited by MK3Dawg
Tbh, had both cars in the family. The interior in the 9N maybe newer, but honestly it felt less well made! Stuff felt plasticy and "soft".....the 6N2 however has a nice interior IMO. But thats in a GTI.
If your into modifing your cars then go for the 6N2, as there are more options...wheels, coilies etc etc
But if you want a comfy car then go for the 9N, they are more comfy to drive.
A basic 9n is definately not £2000 better than a 6n2!
My parents have a 9n tdi. It's a lovely car to drive, and I'm wracking my brain to think of something that has needed repairing. The brake light switch did go, but other than that, theres nothing. It's a 53 plate, still on same shocks etc
I'd recomend one to someone no problems
I can't comment on the 6n2. I owned a mk3 for a few years and have had a drive in a 6n (1.3 SPI) and as a drive, I'd go for the 6n over the 9n. It felt more energetic and the steering's better than in the 3cyl 9n.
That said, I'm an old skool kind of guy... I never resent working on my 'rocco, where the 9n annoys me because it's always silly things that fail that're a nuisance/expensive to change. If I were going polo hunting I'd be looking at another mk3 but with the subframe/suspension arm upgrade.
If I had to choose, I'd spend the £2000 price difference on a higher spec 6n2 rather than the basic 9n.
The 9N interior creaks one hell of a lot I had a 6N2 before and the interior felt better built. The E model is poorly specced and not worth it reallt if you want a 9N at least go for an SE or twist. My 6N2 went wrong a hell of a lot but my 9N hasnt so far although my 9N is a lower mileage car and it a TDi. The 1.2 engine is also has a known fault where the timing chains can snap if they haven't had the updated kit fitted and to be honest the TDi engines are better both on fuel economy and reliability and are worth the price premium in both the 6N2 and 9N and they dont cost much more to insure either
Wow sounds like a 2000 6N2 GTI may be the best option !!!
Will a GTI 6N2 engine do at least 280,000km serviced without engine block treatment or is the turbo making it a 200,000km and break down for parts car ?
Most of what i see online are between 180 and 200,000km, is that OK ?
I drive 4000km a year.
Edited by MK3Dawg
The GTI isnt a turbo. Its a 1.6 16v VVT.
Any engine will last aslong its been serviced and looked after! High mileage ones should have good history. But the main thing with the GTIs are gearboxes and paddleboxes!
