x2 height adjustable 6n2 SE seat bases
x2 seat bases (driver & passenger) from 6n2 SE - height adjustable. Tenner each.
I also have all the other parts of the seats available apart from two headrests. I do have another two headrests plus all the bits you need to fit them. Will probably end up chucking all this pretty soon.
Headrests are £10 for both plus all fixings needed for rear fixing.
Everything else is free to a good home.
  • Replies 10
  • Views 414
If I have standard seats with these frames fit ok??
Did you have a SE with these seats originally or did you fit them to standard seat rails?
Would be good if I could see some pics so that I can work out if they fit!
Where are you located, if your too far can you do posted?
can these seat bases be fitted to the standard seats and is the pattern the same?
I'll try to answer as best as poss and will put pics up tonight.
These are taken from an SE but will fit all 6n and 6n2s.
You can probably take your own seats apart and transfer the cushioning and cloth across to these bases. I have done something similar which is why the seats are in bits. this way the material will match.
postage wise it'd have to be a courier and they're pretty heavy but if you didn't need the cushioning/material I could remove that before sending.
Yeah I think pics will help me understand what you mean!
Bump.
x1 rear headrest plus plastic fixing sold.
Still have the other rear headrest and everything else!
Pictures of one of the seat bases:
anyone?
bump
You still have the seat Subframes for sale? I'm sure these also fit a 6n right?
