Pich bolt missing
Driving to work today and the steering went a little light. Thought nothing of it except to check bolts on the ARB etc. when home. 30 seconds later I'm unable to steer and my front wheels are pointing in different directions :shock: Had to make an emergecy landing on the verge (more out of necesity!) Needless to say losing total control of the car is scary!
Turns out the pinch bolt that holds the TCA ball jount to the strut had disapeared!
Anyone else had bolts come loose/out whilst driving resulting in a change of under garments?
  • Replies 22
  • Views 1.8k
had the steering wheel come off I'm my old robin reliant pick up that i used to rag around the field luckly got it back on before i went through the hedge
had a caliper come off and cheese wedge itself in the wheel!
Exactly same as you. Pinch bolt decided to strip its thread, TCA arm dropped out at the hub end going about 5mp on full lock. Car looked like chitty chitty bang bang on the front drivers side :lol:
I had a caliper bolt come loose too. Though it just swiveled round and rubbed on the wheel. Made a right row though!
I was doing roughly 30 I guess when this went. Only damage wa a buggered inner cv. Which had taken mr the whole morning to sort. Grrrrr!
I did a fanbelt change on my mk2 and went for a test drive, it was fine, so I went home and got ready for work.
Set off for work, got on the duel carriageway and then found I hadn't shut the bonnet properly.
Had a track rod snap on me coming off a roundabout :( Thought it was a gearbox problem as it shuddered to a halt and then wouldn't move at all. Revving it and burning the clutch out. Then I got out to find one wheel dead straight and the other on full lock! :-o
[had a driveshaft fall out on me in my old mk1 golf whilst doing about 65 chasing a lambo lol luckily the whole passenger corner didnt come off as the drive shaft wedged itself in the bay somehow
was scary when i thought about it after as id just come off the motorway doing about 110 chasing the same lambo lol
this was however bitd i dont drive like this anymore
Its funny you should mention this, about a month ago, my tca / ball joint popped out of the hub because the last lad who owned the car didnt tighten the bolt up enough and the ball joint was moving slightly which wore through the pinch bolt. the whole assembly come apart, the wheel went right back, shagging my wing and a drive shaft.
Luckily i was only doing about 5mph, kind of scares me to think that it could have happened on a motorway ect, been over it with a fine tooth comb since.
It's shagged my d/s and wing! Thing is I was on my way to the motor way when this happened. 10 more minutes and it may have been curtains!
that doesnt sound fun.
had a inner CV die on me at 30mph, could have made a right mess of the body but luckly just hit the deck and left a big feck of graze mark. never reused old drive shaft bolts since then
Edited by genesisGT
I had a spare drive shaft knocking about so it was alright for me, iv got another one (think its the short N/S) if your stuck, and i just touched the wing up its a rare colour so got more chance in platting fog than finding one.
And yea iv had 2 cars off here now, and needless to say i wont have another, the amount of half arsed shit on them was unreal, this being a prime example, also found the pinch bolt on the other side was stripped, most the bolts on the car only hand tight ECT.
Had a bolt come loose on me today! The bolt that holds the wishbone on (the one pointing towrads the sump) came free and worked itself out! Steering was all over the place, thought my box was gone. :o
Car was walking across the road when i put power down! :/ had a carrier bolt come lose, so the carrier was resting in the wheel!
Luckily it was the top one that came off so it didn't turn into a cheese wedge! This is my lucky car, i guess. :)
Thanks for the offer of the d/s chief, it was actually my inner cv that was damaged. Had a spare, so it's all sorted now! As someone else said above, been over the car again, tightening all bolts! Thing is I did this recently (when the arb came loose) and it's still worked it's way free! I blame the pot holes!
Oops! My rear engine mount bolt came off on saturday morning, managed to limp the 25 miles to work untilk I tried to get in in reverse and the gear linkage separated.. thanks mr AA man!! :)
Had my rear engine mount bolt come out too, scary times.
Had a driveshaft come out on my old gt doing about 65 - 70, car was so low that as i ran over it the car bounced up and the cv exploded :lol: needless to say the darling (now ex) girlfriend was less than impressed :thumbsup:
when Tollgate Tyres changed my track rod end some how they never put the little clip back on that keeps these bolts from working loose. Several months later my car was worked on by my father in law and he said too me... You're very lucky to be alive after what I've found off your car!
Same thing also happened to a friend of mine in their transit, was not a very nice outcome.
I was taking a 306 from a bodyshop to a spray shop,it'd had a front end shunt so all the front panelwork was electrocoated and just pinned on temp style.
Went down the sliproad onto a dual carriageway,got to at least 50-60mph and the bonnet flipped - stoved in the front of the roof as well as the windscreen as it all went black,extremely loud,not fun as you're joining traffic at that speed..
Saw a post some time back about a guy in an alfa that had his delta mic (ebay special) bolt to hub spacers shear off on his first outing with them fitted. The front wheel just came off and bounced around in his wheel arch at 50mph+and pretty much destroyed the front quarter of the car. He had specifically torqued the bolts up to the correct amount too. The bolts that come with those ebay spacers are the worst tin foil shite metal you are likely to come across.
I use spacers on the rear and they have to be a decent brand, locktite, correct torque and checked every few k miles just for my own piece of mind.
Shoddy mechanics and dodgy second hand/cheap parts are a very scary reality. Thats why it pays to check work you have to have done sometimes. Even better if you have to pay someone else to work on your car that you can fully trust that they will do the job properly.
Its kwik fit, ATS, franchise monkeys that scare me sometimes. Driving out of ATS and then when you get home to find they haven't tightened your wheel bolts up barely at all is a scary thing.
had the pass side driveshaft fall off on my old seat ibiza (i say old it was only a 2001 model and had only done 65k) not really any danger though as i lost all drive! popped the bonnet and found all the bolts which were supposed to hold the driveshaft in on the gearbox end had fallen out. turned out the drivers side was loose too!
lupoluke comment is an interesting one. I too have had a car which has been owned by an enthusiast. they had refitted the std suspension upon selling and not fitted all the right bits in all the right places. the front springs were seated not on spring cups, but instead the rubber top mounts.
Dont get me wrong, I'm not perfect and have bodged shit together. But nothing so bad it was life threatening, and theres no way i would have sold it on knowing it wasn`t 100%, I`ve grew up a bit since and learned that if your going to do it, do it right first time.
Some people just dont have the competance or have a "fuck it, it will do" mentality, that causes problems.
The lad who owned my car before me just come out of his time as a vw apprentice as well which is quite worrying, I'm not having digs and i wont name, its my own fault for not checking.
after finding a seatbelt bolt loose and two wheel nuts
i have gone through it with a fine toothed comb since that. why work on a car if you dont have the right tools just fuking wankers the are the people who do this
