mk3 golf seats into 6n
I'm sure i read somewhere that mk3 golf seats fit straight into a 6n?
is this true?
anyone help me :)
thanks shaun
  • Views 4.4k
is this true?
anyone help me :)
thanks shaun
Yes mate. Front seats are a straight swap but you will need to take the backs off the Polo seats and swap them with the Golf backs. :-)
hi, i've just fitted a set. the front seats go straight in but u have to change the rear back panels because the mk3 golf r wider, i've got the rear seats which spilt in to two. the bottom part, I just changed the metal bracket around. to keep the standed fitting hinge. some people might have just drilled holes and kept the mk3 golf hingers. hope this helps
thanks guys :)
but for the back seats are they bolt on the hinges and stuff or do i need to weld ?
cheers m8
will hopefully do it tomorrw :)
