Removing a 6n2 Steering Wheel
Whats secures the airbag / horn?
Bolts i assume but can't tell WTF they are!
I assume remove the 2 bolts behind, remove the airbag / horn and undo the main nut attaching the wheel to the spline of the rack....
Just need to know how to get the airbag / horn off!
Dave
Found this...
Info on fitting...
Sounds like and is utter ball ache! Why VW WHY?
Edited by DaveG40
it's a complete and utter ball-ache to do, it's only 2 little clips, it took me about 2 1/2 hours. be prepared for swearing when the patience runs out :lol:
Process is as described in the link - basically, just keep messing around with a flat head screw driver till it releases. Make sure you don't do what i did - when 1 clip was released i forgot to wedge it so it wouldn't clip back in then you'll never guess what happened..
Yep, back to square 1!
Good Luck!
