Rolling my arches to stop the scrubbin' with a hammer ...
Just gonna attack my arches with a hammer because my tires are taking some what of a beating so the time has come to do the same to my arches ! I can't afford to go get em rolled somewhere so I'm gonna make do with a hammer unless anybody has any clever method of doing it ?!! Without a roller haha ! ?! Thanks..
  • Views 981
Probably not with a hammer...
I find a baseball bat to be the best way mate.
Just jack the car up so there is enough room to fit the bat in between the arch and tyre, then slowly lower it onto the bat until it's squeezed in there, make sure you don't drop it quickly as it could crack or bend your arch in a funny way lol.
Then heat up the part of the arch you are rolling with a heat gun or hair dryer, whatever you can get your hands on.
Then slowly roll the bat backwards and forwards over the heated up area in different angles depending on how you want your arches to look, and how much you need them pulled by.
Works well for me, give it a try :thumbsup:
Edited by Richibobs
jack handle.. pikey spec.. its not overly pretty tho
did the same kinda way a richibobs on the mk1 fiesta but the only diffrence is i just used a bit of scaffolding bar and just moved the car back and forth.. :D just gotta make sure your arches are not fooked with rust other wise they may just crack and fall out :disgust:
pm me, my friend has an arch roller he would let you use at the unit for not alot of cash (prob 40 buff) but you'll have to do it yourself as any damage to the paint would be on your own back.
in manc
