Chrome plating/painting plastic
Hi,
I am wanting to get a couple of bits of plastic trim done in a chrome finnish, I've tried three lots of so called chrome sprays, but they only turn out to be a normal silver not the nice chrome finnish on the spray can lids!!
  • Replies 10
  • Views 3.1k
i'm in the same boat as you mate- tried all the cans over the years...
Did you primer the plastic first?
Yes tried both grey and white primers, but all the "chrome" sprays still came out a nice silver not chrome :-(
Try some of that chrome wrap off ebay mate
Cheers for those links, I had tried a google search but nothing sensible came up? I will contact qpp ltd on Monday to see if they can help
Any luck mate? wouldnt mind knowing for myself... 8-)
I am trying another route at the moment, I've just received a 2mm thick flexible mirror tile (A3 size) £4.65 if that does'nt work out then I'll reconsider the plating option, but I bet it will be expensive!
how did you get on mate?
what are you doing ?
alclad chrome paint is pretty convincing , although its not cheap and needs to go over minty gloss black to look its best
