Front wing removal
hi everyone
1997 1.4 8v
I was wondering if the front wings are detachable, i.e. bolted only? or are they welded somewhere out of sight.
I need to paint the side sills but want to paint the whole sill including the bit you can't see which is covered by the front wing. The plan was to remove the wings, tidy and spray the sill and bolt everything back together.
Is there more to this job than simply unbolting and removing the wing? i.e alignment of panel issues? Basically i'm asking if its liekly to become a pain in the behind or a simple job
Russ
  • Views 3.7k
Just eight bolts the two at the front can be accessed by removing the indicator and headlights you don't need to remove the bumper but it does make the job a bit easier!!
brilliant cheers NIge mate I'll have a go in a few weeks.
Russ
you have to take the wheel arch liner out aswell but it's only a couple of 10mm plastic nuts and a few torque screws..... easy....
you may also find the wing is glued on in some cases with stuff similar to tigerseal/sikaflex.
cheers guys
I'll unbolt it all when i get round to it and see how it goes (probs few months yet )
I may aswell Waxoyl all the arches whilst I'm at it too
i had this problem just score it with a stanley knife and it'll come off .. its easyier if you jack it up and take the front wheel aswel!!
