Removing the 'Rubber Weld'
I've stripped the inside of my car and decided to keep it pure stripped with nothing other than doorcards in the rear..
I want to make the inside of my car smooth and to do this i have to remove this horrible silver stuff that goes all 'rubbery' when sanding - hence me calling it "rubber weld"..
It chizzels of but it doesnt remove it all meaning that there are some areas with some residue left over that looks even more horrible than it did befor it starteddd!
DOes anyone know the easiest method to remove this silver substance that is covering the seam lines of the metal work on the inside of my car?
Help help help!!!
  • Views 726
Petrol on a rag. I hope your going to replace it with an equivalent soon as the weld is in the atmosphere it will start to rust and quick. So get some seam sealer and then mix your body colour into it. Seeing as your car is silver id get white seam.sealer and add your colour so it doesnt stand out any more.
A drill with a wire brush attachment is best. It will take time though, seam sealer is tough stuff!
