removing 6n2 seats
hey guys, i want to remove my front seats and I've been told to be careful of the seat belt tensioners, is it just a case of i need to take the battery off? I've checked the haynes but doesnt really tell me much apart from how to remove my seats. any help apreciated
  • Views 2.8k
Front seat
Removing and installing front seat with side airbag 10.99 >
Warning!
Disconnect battery earth strap before working on the electrical system.
Removing
Notes:
◆ Before disconnecting the battery see the note concerning the coding in the instruction manual for the radio.
◆ After connecting battery, check vehicle equipment (radio, clock, electric windows) as per Workshop manual and/or Owner's manual.
‒ Slide seat forward.
‒ → Take cover strip -1- off inner seat rail towards rear in direction of arrow.
‒ → Using a screwdriver, press the locking catch backwards and take off cover from seat rail in direction of arrow.
‒ → Unscrew cap nut -1- and remove bolt -2-.
‒ Release locking rod and push seat rearwards out of seat rails.
Note:
◆ Before separating the igniter and earth wire the mechanic must electrostatically discharge him/herself (touch door lock or vehicle body briefly).
‒ Lift up seat at rear and separate wiring harness to side airbag -1- from connector housing -2-.
‒ Fit airbag adapter VAS 5094 into connector housing -2-.
‒ Separate connector for heated seat (if fitted).
Installing
Install in reverse order.
Note:
◆ If the airbag fault warning lamp (K 75) signals a fault after assembling then the fault memory must be erased and interrogated again with fault reader V.A.G 1551
thanks for your reply, I'm pretty sure i dont have side air bags so should be straight forward :)
Yes I forgot to add, the tensioner unit is in the seatbelt reel unit at the bottom of the "B" pillar, so removing the seat will have no effect on the belt tensioner
