Painting around windows?
Hi, how do you paint around windows properly without removing them? Last one i sprayed came out crap, one of the problems was eventhough i masked up the window rubbers, when they flex etc it showed up original paint. Any advice would be really helpful.
  • Replies 10
  • Views 1.6k
if its a mk2 like your sig pic , take the glass out its easy enough
I think I've seen that tape before, cheers for the link i didnt think of it lol
I did think about taking them out but thought all apart from the wind down windows would be a shit to get out..
hiya
if its the fronts wind the window down and take the window rubber off then just mask the hole up ? :)
hiya
they're the easy ones, i meant the fixed windows. Front and rear screens and rear sides. But i got tol today you can use a piece of wire cable cut lengthways and will lift the corner of the rubber up
I used wire. get some kinda chunky wire and shove it under the seals. lifts them up enough to get paint under there.
take the door off and wind the window down and whip the seals off. wouldnt take too long
Not that easy with a door, they dont just 'come off' I attempted to remove them from mine but gave up and taped around them. There also solid, couldnt get wire under um.
I was just talking about the windscreen/quarterlights.
iv had a door off before, wasnt tooo bad. depends how thorough a job you want to do really! an extra pair of hands helps though!
Getting the door off was easy, i was talking about the seal around the window.
I did a pretty thorough job though... ;)
