WET 6N open air
HI
I have had a serious problem over the last year, my open air polo has been leaking badly have tried various solution but first the wet parts:
  • driver and passenger carpets wet as hell
  • water on the rubber mat possibly from under the dashboard because a small puddle always formed in middle of the mat
  • wet headliner on the corners of the sunroof both back and front.
  • Doors fill up with water
the things I did to try and prevent this
  • Patch up the roof
  • Abusive amounts of sealer around sunroof
  • Cleaned the door drains
Some other solutions that i was told about were about some drains aoround the sunroof, I have had it apart a couple of times and never seen pipes or drain of any sort.
Its was really desperate during the rainy months, and now is my chance to fix it, in a week I am finishing college so plenty of time to work on the car while job searching.
Edited by danielmi
  • Views 1.9k
Not have someone at it with a waterhose on and have you inside tracing the leak, that's about the highlights of how we checked when i worked at VW lol
Yeah was kinda trying to find a way round that but it seems that its the only real way of sealing the damn thing. I will remove the interior panels/roofliner as well(they need a retrim anyway) should make things simpler. Cheers
We bought an open air last week and this had similar issues.
Water in the footwell will be coming in from where the pollen filter is. This always gets cloggged with debris and then mud and instead of the water going down the drain tube into the wing/wheel well it just pours in through the blower and into the passenger footwell.
As for water in the roof area you will need to remove the head lining and then take off the roof spoiler. Normally you will get a leak around one of the mounting bolts/screws. This is usually easy to see as there is rust around it on the inside of the car. Clean it up, treat the rust and then use a drop of automotive silicone sealant around each fixing hole before you refit the spoiler.
I know its late but I hope this helps.
